Application Scripts |
AppleScript is perfectly suited for integrating different applications, interchanging information, and creating workflows. DEVONthink comes with a number of scripts that exchange information between DEVONthink and other AppleScript supporting applications, like Safari or Mail. The Script Menu Extra Scripts provided by DEVONthink are installed in an application-specific folder in Mail Scripts Importing email into your DEVONthink databases is a possible use of AppleScript. Using AppleScript-enabled email applications, especially those with a robust scripting dictionary, increases the potential for processing emails. This can help you quickly file those emails directly into DEVONthink. DEVONthink comes with scripts for Apple Mail, Microsoft Entourage, and Microsoft Outlook. Just select a message or mailbox in a supported email application and choose the desired script from the global scripts menu. DEVONthink provides the following scripts:
PRO
Web browsers Depending on the capabilities of the web browser you're using, you may be able to use application scripts. We have included a handful of simple scripts that can be run while browsing in Safari or DEVONagent.
PRO
Other Applications Obviously we haven't covered all the possible applications or scenarios on your machine, and we are sure you have ideas we haven't thought of. If you have an application you'd like to integrate with DEVONthink, check if it has an AppleScript dictionary. If it does, the potential exists to communicate between the applications. But also be aware the commands, elements, and properties you can work with are coded by the developer of those applications. |
