Triggered Scripts |
Triggered scripts are AppleScripts that you attach to an item in DEVONthink (a group or document) and that are executed each time you select the item. Items with attached triggered scripts show an AppleScript icon behind their name. Using triggered scripts, you can add your own custom behaviors when interacting with items in your database. Attaching a triggered script While it's possible to write a script that specifies a triggered script for an item in DEVONthink, the usual method is manually attaching one.
Removing a triggered script Since a triggered script runs when you interact with the item, it can sometimes be difficult to detach the script, e.g., if a script switches to another application when triggered. For instances like this, to remove a triggered script from an item do the following:
